Originally Posted By: Squirrelee
Originally Posted By: WyrTwister
I will probably get yelled at . For at least 20 years , I only add water to a cooling system , in case of an emergency . And also use only 100% coolant . Not 50-50 mix .
My theory is , no water , no rust .
Up until 2015 , my only experience with coolant has been the traditional green coolant .
I have a 1991 Caprice running it now . A 2006 Buick and 2015 Sonic running Dexcool .
If it works, it works, but you are losing "specific heat capacity." Depending on how far south you are in Texas, you may want more (much more) water than coolant.
Read more here.
I understand what you are saying . Please consider this .
A - I have never had any problems with 100% coolant .
B - I am sure 100% coolant , cools better than a cooling system / radiator that is partially degraded by rust and deposits .
C - And if I blow a hose , I can refill ( in an emergency ) with water & still have sufficient coolant .
D - No water , no corrosion / deposits . I have had to have a radiator rodded out , in the distant past . Not an issue with 100% coolant .
