Hi,
in testing done by Glacier "Cleaning of lubricating oil - The needs of the future" (using a 15w40 lubricant, 3x 2.5ltr Turbo intercooled diesel engines)in 1995 it was found that a centrifuge captured the
The engines filters were
1 - FF filter
2 - FF filter, plus centrifuge
3 - 45 micron FF SS screen, plus centrifuge
In the trapped contaminant "mix" the following % of particles were found;
>10m = 1%
5-10m = 1%
3-5m = 2%
2-3m = 4%
1-2m = 20%
0.5-1m = 29%
0.25-0.5m = 25%
Roughly 91% of contaminants were less than 2m
IMHO this is but one reason why HTHS viscosities have become increasingly important. Most long term wear is likely to be caused by particles below 15m - a significant amount is below 2m
It was found that engine 3 had a 300% increase in Iron particles over engine 2 indicating that a normal good quality FF filter will trap contaminants down to 15m
Heavy diesel engines using a centrifuge certainly appear to show much less wear in valve trains, bearings and piston/cylinder areas than those without. This has been my experience
