What is the highest QUALITY Mobil 1 30 weight ?
Originally Posted By: Captain_Klink
Mobil 1 USED TO BE premium, but now it's just watered down usual cheap "synthetic" with the same marketing hype to guarantee huge bonus for CEO. Remember: The Corporation is under NO OBLIGATION to you the consumer, the OBLIGATION of the corporation is to deliver MAXIMUM PROFIT to the shareholder. I basically changed my mind about my favorable impression of Mobil after reading here for a while. also check the Mitsu forum, with published Blackstone. The Shell Rotella T was better than Mobil, with almost THREE TIMES the mileage!!! I had 4 jugs of AFE 0w30Mobil 1 in my stash, which I returned to Walmart, for some RELIABLE and CHEAP MC5w20 and ST5w30 (Semi Synthetic MC, Full Synthetic ST)
http://www.3si.org/forum/f1/mobil-1-blackstone-analysis-you-might-want-see-450024/
You SERIOUSLY need to familiarize yourself with Doug Hillary's article on used oil analysis.
You are drawing conclusions with this data where there are none to be made, sorry.
The point is that you get the EXACTLY SAME LONGEVITY with Mobil 1, or Pennzoil Platinum, or probably even BozoTheClown Brand SM oil, PP easily can run just as long as Mobil 1. Nowhere have I seen any shred of evidence that there is the tiniest bit of advantage running Mobil 1 vs any other synthetic. And everywhere we see BozoTheClown Brand oil changed every 3-5K with NO ISSUES. Of course Mobil has a premium formulation, made for racing, but the don't sell that to us. What we get is a jug with the NAME Mobil 1 on it, but what is inside the bottle is a product that is GUARANTEED TO MAXIMIZE SHAREHOLDER PROFIT, that is how a corporation works. A Corporation IS REQUIRED BY LAW to do that.
My current DD has 200,000 miles on it, and it has been fed a steady diet of CONVENTIONAL OIL ONLY 5w30 SJ, SL, and nowSM. This is just a Mitsubishi 1.5l 12valve OHC 4 Banger. It uses zero oil. It runs so quiet you can barely hear it, it runs like a top, and I recently took it up to 90 miles per hour on the interstate as a test, and it runs perfectly silent at that speed, with no sign of being short on power.
In the majority of applications, I am sure you are correct. However, an oil like Mobil 1 0w40 is not covered here, and there are a number of high-performance applications that specify this oil, or a certification that this oil and very few others meet.
I'm sure if you asked Porsche, GM, Mercedes, Honda or any other manufacturer that does extensive in-house testing of a variety of oils that they could give you a reason.
Mobil 1 was the first oil to meet Honda's demanding HT-06 specification for example.
Even the Toyota sludge-prone engines eh?
Nope.
There are a number of applications, like the one I just touched on that benefit from the use of a synthetic oil. These are NOT the majority of applications of course, but they do exist.
Our very own Pennzoil Johnny made a thread about the use of off the shelf Mobil 1 being run in the vast majority of cars at Daytona.
And you have ZERO proof that the product is in any way inferior. In fact the vast assortment of manufacturer certifications and approvals; more than ANY other oil company, is a good indication that what is IN the bottle is BETTER in many respects, and TESTED to be better BECAUSE of those specs, than the vast majority of readily-available oils out there.
To make money? Yeah, that's the typical goal of capitalism. That does not mean that one sabotages their own product line in order to artificially inflate their profit margins though.
I'm not sure how 92HP could be another OTHER than short on power, but anyways....
MOST engines will live a long an event-free life on an approved off-the-shelf conventional lubricant.
There are SPECIFIC SITUATIONS where a particular engine or application REQUIRES THE USE of an oil that has a certain approval or certification above and beyond the basic API one, and the vast majority of these applications are PERFORMANCE ORIENTED.
This is the REASON companies like Mercedes, Porsche, Honda, VW, Audi, SAAB, Ford, GM, Chrysler, Ferrari....etc create these additional certifications; they need the oil to provide ADDITIONAL protection above and beyond the scope of what is dictated by the testing done by/on behalf of the API. They create their own unique tests that must be performed, and then, where the situation demands, SPECIFY THE USE of oil that MEETS that certification.
Mobil 1 happens to be the oil that meets the most of those certifications. They are usually the FIRST to meet those certifications and to garner those approvals as well.
Love or hate the product, Exxon-Mobil SPENDS the money on R&D as well as on certifications and approvals so that you know what you are getting: An oil that meets the most demanding manufacturer specs across the globe, and subsequently covers the broadest range of applications.
And yeah, they are the most profitable company of all-time but hey, that doesn't mean they make junk. Which seems to be your train of thought here.
Wait a minute. You implied you used Mobil 1 0w30 in your Mitsu and returned your stash to Walmart. after reading on BITOG. Now you also say your MITSU has 200,000 miles all on dino. Which is it?
I'm running Mobil 1 high mileage 10w30 because its on sale for $22 in 5 quart jugs at wal-mart, bought enough for 2 years worth of oil changes, at 8,000 mile intervals.
I just recently bought some Mobil 1 because I thought 22$ a jug was a reasonably fair price. However, I have never actually used any Mobil 1 synthetic, except for in the gearbox. I use Mobil 1 Extended Performance 5w30 mixed 50:50 with Pennzoil Synchromesh in the gearbox, and it does a wonderful job. My Mitsubishi was inherited from my brother, who put on all those miles, and I believe he used Castrol GTX 5w30 conventional every 3000K or so. 92 horses is plenty for a 2000 lb. car. This is the exact same power to weight ratio as the famous BMW 2002. I had a 1971 2002 which boasted 96 hp!!! The 2002 is one of BMW's most famous automobiles. Mine was retired with about 350,000 miles on the original engine. The oil used was 10w30 Castrol CONVENTIONAL.
The Mitsubishi Mirage on the other hand, at one time held the world land speed record for a stock 4 cylinder. And my Mitsubishi is every bit as fun to drive as my 2002 was. None though compares to my 2008 Subaru Impreza.
Thanks for clearing that up. There's a lot of good oils to use, but you seem very criticle of M1 since you have never used it.
the higher groups - 4, and 5, have less tenacity. higher tenacity is from group 2 and 3, and since that equals greater film strength and better protection, i stay away from Mobil 1 altogether.
Just use a proper oil that everyone here KNOWS works well, with many many exceptional UOA, like Pennzoil Platinum, 5w30. if you drive mainly long highway miles, you may also opt for Pennzoil Platinum 10w30. for that matter, even the lowly SuperTech synthetic 5w30 gives stellar UOA, even with 10,000 mile OCI. I don't even know why anyone is asking about Mobil 1 - strictly bragging rights as far as I can tell.
1. Group V (POE) has the highest polarity.
2. used oil analysis tell you nothing more than oil LIFE for the most part. Drawing wild conclusions from single-digit discrepancies in Pennzoil PlatinumM values is nothing more than an exercise in futility.
3. Mobil 1 is the factory fill for a huge list of high performance cars. I'm sure Mercedes, Porsche, GM...etc are all doing this just for "bragging rights" for the consumer......
Think about it though. Who would be impressed by Pennzoil Platinum being factory fill? I mean, besides BITOGer's.
Everyone has heard of Mobil 1 and seen them sponsor cars/drivers and their advertisements in magazines and on TV. That alone is what drives most people to pick Mobil 1 over anything else.
Probably the same people who are impressed with Mobil 1 being the factory fill. Pretty basic brand-association...... When a CLK-GTR comes with Mobil 1 in the sump, I'm sure a lot of people take note.
If the Saleen S7 came with Pennzoil Platinum in it, there would be an immediate "quality" recognition with many consumers, just like the above example with Mobil 1.
You know, the more I learn on here and the more I read your posts, the more I'm tempted to try the Mobil 1 0w-40.... or Redline 10w30. The ACD has served me well and I really want some real teardown results on one oil for life but I'm getting restless and wanting to change just for change's sake with 76,000 miles on the same brand.
Originally Posted By: tig1
Not me.I used M1 when M1 wasn't cool.
When was using M1 un-cool ..or rather when was M1 uncool?
Certainly.. Mobil 1 has done a great job of making them the "in"oil to use. Great marketing and product placement. You know what I thing.. I would rather buy product with my money than finance marketing.
My Mustang was 3,200lbs, 325HP, the Capri, which is older and lighter is 2,800lbs, and with the new cam, carb swap and other fun stuff, should be in the neighbourhood of 425HP. Same engine, currently has 330,000Km on it.
So maybe I'm just a touch jaded
Last car I drove with 98HP was a Saturn SL-1, and it was similar weight to your Mitsu.
Originally Posted By: Bryanccfshr
Superiority complex?
Naw, drag-racing fetish. Grew up around V8's, got addicted to Mustangs, and then started going to the track. It pretty much snowballs from there.
M1 was the first oil to meet Honda's demanding HT-06 specification for example.
Isn't that because they were the ones that came up with the specs?
I thought Mobil 1 was always a cool motor oil......
It's only cool because of the brand recognition and sponsorship. That's something few other oils will ever achieve, even though they're better products.
No, Honda came up with the spec, that's why its their spec........
Not me.I used Mobil 1 when Mobil 1 wasn't cool.
You may not be old enough to remember when Mobil 1 oils came. I started using Mobil 1 in 1978, and Mobil 1 wasn't heard of by many people then. In 78 I paid $5.00 a qt. and it could only be purchased at Mobil gas stations. There was no brand recognition then or sponership, except for F1 in Europe which meant nothing here.
As far as quality goes Mobil 1 has done a great job for me, but I never said it was the best oil out there, but it is amoung em.
