Marlin I belive you are oversimplifying things somewhat regarding DEX-COOL. ALL the newest Prestones, and ST, too, are essentially a DEX-COOL whether they state GM approval or not - no phosphates, borates, amines, nitrites, or silicates. (There is some room for formulation difference in the GM DEX-COOL spec regarding the hydrated carboxylic acid salt(s) used as corrosion inhibitors.) But that generalization does not apply to Zerex, Peak and other brand extended life formulas you named. Many of these still employ some silicate and/or phophate content which is most assuredly outside the GM DEX-COOL spec. Prestone took their own DEX-COOL formula, dropped the DEX-COOL name and GM imprimatur, dyed it green instead of orange and that's what use as their reformulated standard "yellow-jug" antifreeze/coolant - all but DEX-COOL in name. ST is apparently identical (and probably supplied by Prestone in bulk for rebottling by WalMart's supplier, "Alsip Packaging, Inc.").
BTW, for anyone suspicious of the new ST extended life antifreeze/coolant at WalMart, I've now been running it in my very early '03 Sonata's aluminum block Hyundai V6 for three months. (flushed repeatedly with WalMart's "best" distilled water & changed in mid-August to about 45% concentration according to my Prestone hydrometer - the 2nd anniversary of my car's build date) I've kept close tabs on the new coolant. No cooling problems at all to report and from what I can observe of the radiator core and the appearance of the overflow bottle, both are still gunk-free, and as clean green and transparent as an emerald. No scaling or sediment visible on the metal parts in the radiator, either. Not certain what Hyundai used as factory fill, but since the owner's manual specifies a 2 yr./30,000 mile change schedule, I suspect it was some Korean variation of the traditional silicate green-snot-of-death crap. The Hyundai factory fill coolant drained very slightly cloudy, though it hadn't yet discolored or gelled noticeably. Nevertheless, that slight cloudiness makes me wonder whether I might've nipped something nasty in the making.
