JHZR2
Staff member
I love JD Cool Gard II in my old diesels. I have it running perfectly successfully in the following:
1996 Dodge Ram Cummins 445k mi
1996 Dodge Ram Cummins 266k mi
1991 MB 350SD 203k mi
1991 MB 300D 233k mi
Well, the 350SD had it perfect. No issues. Had the OE plastic radiator.
In the summer I had a Chinesium fan clutch fail, throw the fan into the radiator. That story is on here. The OE plastic radiators are NLA, so the only choice is a welded aluminum radiator that fits in the same spot. Seems to work fine. But I recently noticed some oddities.
The cool gard seems to be seeping out!
Noticed this yesterday:
Clamp is plenty tight. Wasn’t chanced or adjusted in probably a decade. Didn’t need to loosen it when changing radiators.
OK, so maybe that’s not alarming…. Well, it’s seeeping through the hose:
It’s definitely yellow coolant. It’s not enough to change the level at all. In fact, a few thousand miles after changing that radiator, the level is still at the full top of the pressure bottle.
It dries to this:
But it’s more…
It’s seeping at the upper purge hose…
And the drain plug.
Nothing is at a torque level that I’d be comfortable with going tighter.
Maybe the one hose has failed internally?
I’m not blaming Cool Gard. As I mentioned, I’ve ran it for a long time in multiple diesels with great success and very clean systems.
But just an interesting observation. All in one vehicle. No indications of anything anywhere else on any of the other vehicles.
It dries to this:
But it’s more…
And the drain plug.
