https://amsoilcontent.com/ams/lit/databulletins/g2883.pdf
Looks like the Amsoil 10w30 also has a pretty good HTHS of 3.6 too(almost a 40 grade). You're using z/p ppm and viscosity.
Many of the motorcycle oils have a good z/s/p/ca. You'll have to research the grades and brands in your area of full synthetic motorcycle oil and see which ones have that z/p that you want, whether you need it or not is irrelevant.
Not like there is an unlimited supply of A40... visit Porsche dealership? or maybe only Mobil1 around? Or the MB dealership for one of their higher z/p oil specs. Guessing walmart and canadiantire oil selection? new car/motorcycle/snowmobile dealers? or what autopart stores around you?
I also don't think that the gurus do anything but ride the bandwagon. But, I won't blame you if you want your z/p. I mention z/p together because vaguely remember that p was more important than z. The more I hear about z z z, the more I wonder if anyone ever worked in a failure analysis lab or some standardized component wear lube testing since I also want s s s with the p p p and you can keep your z z z. Gurus can be fools. Its the performance of the total additive package that is more important than z content. So, foolish gurus picking an oil based simply on z PPM is dangerous.
If available, nothing wrong with RoyalPurple HPS oils.
https://www.royalpurple.com/wp-content/uploads/2022/02/Royal-Purple-HPS-PDS-06July2021-1.pdf
Consider any BRAND A3/B4 oil, 0w30, 5w30, 0w40, 5w40 for example:
https://www.castrol.com/en_us/unite...castrol-edge-brand/castrol-edge-euro-car.html
https://www.valvoline.com/en/european-vehicle-full-synthetic-motor-oil/
https://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum-euro.html
I'd also consider:
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-fs-0w-40/
https://www.mobil.com/en/lubricants...ts/products/mobil-1-turbo-diesel-truck-5w-40/
Also, Ford's Powerstroke list of oils have various grades to choose from in their list, and their statement is also a good read:
https://www.fcsdchemicalsandlubricants.com/Products/Details?cid=70&pid=462
And, since your location might not be shipping friendly, the 5w30uhp or 5w40uhp:
https://lubricants.petro-canada.com/en-ca/brand/duron-uhp
You should gather UOA data trends with your Amsoil z-rod stuff, and then compare to the 5w40uhp, FS-0w40, or Edge A3/B4, and see if you'll still keep that z addiction.
Dose this with any temporary current spec full synthetic oil you pick.... maybe 2-3 ounces per gallon of oil: But, I prefer a properly blended oil and not blind additive dosing.. but the product is there if you're waiting on your Amsoil shipment:
https://rislone.com/products/hy-per-lube-zinc-zddp-supplement/
