Originally Posted By: ragtoplvr
Bushing engines can go to 24 to one, no less. All needle engines can do less, all needle lawnboy engines were 64 to one, but they had so little excess oil that they rusted over winter so went back to 32 to one.
C engine lawnboys have lower bushing and some have bushing con rod. They can go no leaner than 24 to one. Later C lawnboys and D engines can go to 40 to one but no less as they have a lower bushing.
These engines have a removable cylinder.
The later F engines and up with the plastic carb are all needle bearing, but it occasionally score a piston on 50 to one, so I recommend no ethanol it messes with the carb. You can use 40 to one premix if you can afford it. Run the gas out of the carb every time.
I still have lawnboys running, used one this morning without waking the neighbors.
Rod
Great advice! I do much the same. They really are great mowers! Mine has either the all aluminum cast body or magnesium, can't remember.
In 23 years of service, I've never had to clean the exhaust ports of carbon. They were still clean. I'm still running on the original plug.
