- Joined
- Nov 24, 2023
- Messages
- 192
Natural gas , mounted on outside wall .
What do you mean winterizing? Is this a dwelling you close up for the winter?Natural gas , mounted on outside wall .
Louisiana . Very common to mount gas units externally here .What is the location? it should be somewhere warm like florida if its mounted outside the house.
EggzacklyNothing to do except make sure all exposed pipes are properly insulated with foam pipe insulation.
If it's a full time residence then why are you winterizing it .Full time residence . Not my own . I don't have a manual . Friend .
I think alarmguy got it right . Some of us thought he meant Winterize before vacating but he really means prevent a freeze up . So as suggested ..... insulate the pipes or install styrafoam cover around it . Here we use faucet covers in the winter to keep pipes from bursting . They hold heat around the faucet and piping .What do you mean winterizing? Is this a dwelling you close up for the winter?
If not, you dont do anything but make darn sure the piping is properly insulated outside and I mean no exposed pipe anyplace.
How cold does it get ?Louisiana . Very common to mount gas units externally here .
We just had temps down in the teens and I had heard of them having issues with really cold temps . Trying to figure out if it's even necessary .If it's a full time residence then why are you winterizing it .
We use those for faucets here . Not applicable for this .I think alarmguy got it right . Some of us thought he meant Winterize before vacating but he really means prevent a freeze up . So as suggested ..... insulate the pipes or install styrafoam cover around it . Here we use faucet covers in the winter to keep pipes from bursting . They hold heat around the faucet and piping .
You used the wrong word which was where the confusion came from.We use those for faucets here . Not applicable for this .
The faucet cover was an example . How about getting an styrafoam cooler and cutting it to fit and attaching to the house some how .We use those for faucets here . Not applicable for this .
The only reason some have issues on cold single digit or teens temperature is the plumber who put the insulation on the pipes outside the water heater on any particular house did a sloppy job.We just had temps down in the teens and I had heard of them having issues with really cold temps . Trying to figure out if it's even necessary .
