What sort of fluid has the biggest Viscosity Index? Gear oils or engine oils, or ATF?
I'm looking a fluid amendment to add to my MT to thicken the fluid at high temperature, without making it too viscous at cold temperatures (near freezing).
In other words, I'd like improve the VI of my MT fluid.
So, I'm currently running ATF 3 in my 1995 subie 5 speed transmission, because the regular 75w140 is too thick in the cold (where the transmission no longer shifts into 2nd gear until the car has reached operating temperature).
With ATF 3 it shifts into all gears; however, there is a slight problem once it's very well warmed up: during shifting from 4th to 5th during higher RPMs. I'll hear that it will grind some part of the transmission (synchromesh?) during this shift. So far, the transmission has put up with a lot of this grinding wear over the years and held up, but if I could improve it, I believe I'd extend the life of the transmission.
So far, my candidates to add into the ATF III are:
STP oil treatment
75w140 gear oil
0W40, eg. mobil
5W50, eg. castrol
How does the 75W140 compare to say an oil like a 0w40 or 5w50, and what else might you consider as an additive candidate? If it matters, the transmission is integrated (shares fluid) with the AWD differential--and I believe I've heard that stuff too rich in slippery stuff like MoS2 is not recommended).
STP oil treatment
75w140 gear oil
0W40, eg. mobil
5W50, eg. castrol
