Last time when I replace the coolant bypass hose, I noticed some scales and crud in the area. I figure the next time I replace the coolant I will do a chemical flush/cleaner before I put new coolant in.
2 years later my radiator's top tank cracked, and the warning on the new unit said I have to flush and fill with distilled water mixed coolant or else no warranty.
So I am thinking about either the Prestone's Radiator flush or cleaner. Both seems like identical formula but the cleaner is stronger (need 2 rinse before putting in final coolant) and takes longer (3-6 hours) than the flush.
Which one should I use? I am leaning toward the stronger one, but are there side effects?
