What do you think about putting Slime in car/truck tires? I tried some in my motorcycle front (tube) tire because a flat at highway speed can be very dangerous, but I don't think it worked very good. The front tire always felt out of balance even though the tire was balanced before putting in the Slime. I could not use and old tube with Slime on a new tire because of this balance problem.
I have used Fix-A-Flat so I could drive off the main highway to fix the tire properly, and it seemed to work. FAF if different than Slime: It is more liquid.
A mechanic friend of mine that sometimes replaces tires get mad when he pops a tire off the rim and Slime oozes out all over his machine. He has a clause on the service order that tells the customer he will charge them extra if he has to clean Slime off his machine.
