V Vikas Joined Jul 22, 2005 Messages 11,980 Location NorthEast Sep 27, 2012 #1 I tried paint thinner and that did not work. It did not mix with the touch-up paint. Do I need to buy acetone or nail polish remover?
D dave123 Joined Jan 13, 2009 Messages 2,935 Location wi Sep 27, 2012 #2 Acetone MEK NBA Normal Butyl Acetate Ethyl Acetate
Y yonyon Joined Mar 6, 2012 Messages 3,492 Location NJ, USA Sep 27, 2012 #4 Assuming the label doesn't have any recommendations, does it tell you anything about the paint at all? Worst case, you have no label at all, try using a thinner that smells the same as the paint.
A ARCOgraphite Joined May 17, 2009 Messages 22,440 Location N.H, U.S.A. Sep 27, 2012 #5 Toluene? Nitromethane?
S SatinSilver Joined Jan 24, 2008 Messages 13,506 Location OH Sep 27, 2012 #6 Buy a new bottle of touch up paint if your current stuff has thickened due to age.
DBMaster Joined Sep 18, 2012 Messages 6,252 Location DFW Sep 27, 2012 #7 Acetone will probably work, but enamel reducer (could actually be one of the chemicals Dave mentioned) is similar to what a paint shop would use. It might be tough to find in small quantities, though.
B Benzadmiral Joined Oct 12, 2005 Messages 5,760 Location Da Swamp Oct 15, 2012 #8 Lacquer thinner? I use that to clean my brush after doing a few touch-ups.
The Critic Joined Aug 30, 2004 Messages 35,366 Location CA Oct 17, 2012 #9 Just use a toothpick, and you will not have to worry about thinning it out.
