Originally Posted By: Nick1994
...What can you guys tell me about it?
It'll very likely run as long as you need it to with minimal care and feeding. It'll likely leak oil from more places besides the oil filter.
Please see the Camry in the signature block. I've owned it for 6 years and, consequently, now know quite a bit about the 4th generation Camry and always willing to share what I know.
Originally Posted By: Rolla07
Check the water pump also.
FWIW, original (Aisin) water pumps are known to last roughly 200k miles. In fact, I just did a timing belt, pulleys, and front seals job on mine a couple months ago and intentionally skipped replacing the 6-year-old Aisin water pump with 70k miles on it. I don't like doing things twice and I'm not expecting to need to do so in this case.
The only maintenance records I got was a sheet from Brakes Plus it was:
Transmission flush
Coolant flush
4 new struts
Alignment
Power steering pump
Radiator hoses
Sounds like preventive maintenance, the power steering pump notwithstanding.
Originally Posted By: 440Magnum
Originally Posted By: Donald
Who drops $2200 on a car that old? He should have sold it.
Seriously??? $2200 on a heavy maintenance is no big deal. You should think in terms of how much it would cost to replace the vehicle with an equivalent or better, and its a heck of a lot more than $2200.
What doesn't make sense is doing that kind of maintenance and then selling it. A maintenance bill like that makes sense if you plan to keep it few years, but not if you're going to sell within six months.
It's possible that the previous owner intended to retain the car for much longer than that. Sometimes circumstances don't play out according to plan. Perhaps that's what happened here.
Originally Posted By: TomYoung
...I am always up for a "business analysis" but would caution folks about two faulty ideas in this note. The first is the idea that there is a straw that breaks the camel's back. There isn't. The second is that the cost of the repair should be weighed against the price of the car. The correct business case is to weigh future utility expected against the cost of new or newer cars and their expected utility and cost.
