I'm not even sure I'm using the right term because I have basicly no experience with any uneven wear, besides light feathering on the front tires. This is where the treadblocks on the edge get faceted. Not "scalloped" where there is a bit scooped out like from a spoon, this is where those blocks get worn at an angle, in some cases every 3rd block has a high spot.
I don't think it's my rotating or lack of rotating them, since there is another new set that came on the CRV, still in use, that wore perfectly flat (Nexen). This is the TRZs, and all 4 tires have it. All have about the same total wear too.
I hate to whine about it, but they are loud, and it bites. I plan on installing them, so the "sharp" part with the oblique angle hits the ground first. Sort of a cross rotation. I suppose that wears them flat eventually. that's why I also shaved them square too. yep, I shaved them.
Anyway, what causes it and what can be done to avoid it?
