- Joined
- Nov 29, 2009
- Messages
- 10,258
So back in February I spent $2200 to replace the entire front end on my dodge 2500 and one front wheel bearing to get the abs light to go off. Then shortly after that I bought 4 new tires. Should have replaced the rotors too because they were warped, so anyways, it didn't take long for one of the front tires to go back to having cupped wear. For some reason one part of the tire is tread is flat compared to the rest of it so it sounds like you're driving over an expansion joint in the road. Anyways, fast forward to a couple days ago, duscount tire asked for a review so i left a crappy review on these tires because I've gotten several sets and they are always rough riding junk tires, but I keep buying them because my truck will chew through a set of $2000 michillens just as fast as a cheaper set. Anyways, discount tire called becaise they didn't like my review, but I'm like what are they going to do?
btw these morons never balanced them correctly to begin with because there was some confusion about what type of weights they were supposed to use, then the girl said oh we can put the tape on weights instead if you like. For whatever reason the message never got through and I told them to just do whatever because I was about 30 seconds from blowing a gasket over how such a simple task could be so confusing. Anyways, the bottom line is should I take the bait and go back down there to see what they can do? I suppose rebalancing the tires wouldn't hurt, but I don't think cupped tires can even be fixed. Sorry about my rant here. I'm really not in the mood to spend any money on tires right now. I supposed I could rotate them to the back, but I don't like the idea of something out of balance shaking up my rear differential
