atikovi
But this happens without using flash too.This symptom tends to occur in low-light environments when using a compact digital camera because of the proximity of the flash to the lens assembly. It is not a malfunction.
It's a massive ghost fart.From Sony:
What are "orbs"?
If specs of dust particles are floating in the air when you're taking a picture, they can be illuminated by the light of the flash and sometimes appear in the image as white, round glare spots, also known as "orbs". This symptom tends to occur in low-light environments when using a compact digital camera because of the proximity of the flash to the lens assembly. It is not a malfunction.
From Wikipedia:
In photography, backscatter (also called near-camera reflection[1]) is an optical phenomenon resulting in typically circular artifacts on an image, due to the camera's flash being reflected from unfocused motes of dust, water droplets, or other particles in the air or water. It is especially common with modern compact and ultra-compact digital cameras.[2][3]
A hypothetical underwater instance with two conditions in which circular photographic artifacts are likely (A) and unlikely (B), depending on whether the aspect of particles facing the lens are directly reflect the flash, as shown. Elements are not shown to scale.
Caused by the backscatter of light by unfocused particles, these artifacts are also sometimes called orbs, referring to a common paranormal claim. Some appear with trails, suggesting motion.[4]
These have happened randomly for years and cleaning the lens doesn't help. Is there something in photo editing software that would erase them? No it's not the ghost of a previous owner.
