What are you working on today?
Finishing tree removal, brought down by straight line winds during a thunderstorm. Tree had some rot in the center.
Needed all of my 32 inch bar.
Put the bottom transmission belly pan back on the X3 after the total VR&P ATF changeover. It's been 600 miles and the pan's not leaking. The trans is shifting better with no new bad stuff going on. So I'm not going to be draining or fixing anything where the belly pan would be in the way = pan back in place.
This week oddly I had a '99 and 2000 Taco with the same complaint: p/s leak. Both trucks were leaking from the same place, which was the return line.
The OEM return line eventually gets hard as a rock and either leaks at the clamps or just "oozes" fluid through its pores (not sure)
The 2000 was still a little noisy after bleeding lock-to-lock. I was able to just set this rubber block on the reservoir and it held to allow vacuuum. Vacuum bleeding took it from a small but definite whine to a barely perceptible whine -- good enough at 270k miles
The 2000 also got an engine oil change, new air filter, new wipers and new a/c condenser and accumulator. Toyota opted to put the latter two about 1/4" behind the bumper, ensuring that the lightest tap means a/c damage.
Neither AutoZone or O'Reilly lists a condenser for these first gen Tacos -- like at all -- so I had to order from RA. I got a UAC and unfortunately the fit sucked :rolleyes:
Job done.
Alternators on the generation J-Series cars I have are pretty much a cake walk. Sure you have to move a few things out of the way, but there are plenty worse jobs.
Hardest part for me is re-installing the belt. Kicks my arse every time.
Alternator fresh off the boat from China WAI GLOBAL 8296N. New, not reman. New Bando belt as well.
And yes, I did go back and plug the cooling fan in.
New positive battery terminal. You have to love Honda back in the day. No extra BS on the terminal, just wires crimped on.
Alternator making good voltage at high idle.
Just about all the load I can put on the thing.
I do have to chuckle at the complete and utter BS spec sheet they send with the alternator:
24 amps of ripple current? I certainly hope not.
Ohh well, we'll see what kind of life I get out of it. The OEM packed it in at 320,000 miles.
2009 Ford F350 6.4, somehow still alive at 231,750 mi:
-replaced both fuel filters
-engine oil change. The filler cap is the ratcheting type and had failed so the top just spun by hand while the threads stayed put. Apparently a VERY common problem. The Motorad logo here explains everything you need to know:
I decided rather than ordering a replacement I'd just apply copious SuperGlue (excess visible above), pop the two pieces back together and make it a non-ratcheting cap. Seems to work fine.
I JB'd the ratcheting gas cap on one of our BMWs when it started to just spin. As long as it stays put there's no EVAP code. Beats $69 for an OE cap or $30 for a Chinese one that will just break.
Worked on the mini-ex in the heat.. 5 pieces later the filter is hooked up. Wired up the fan to a switch, and even has a fuse lol. Scratched my head on the fitting going in the pump. Replaced the o-ring on the hose and put a little black rtv on the fitting to pump, didn’t have the right size rubber washer. Had a off/on leak not sure if its fixed now.
Skid for a 50 gallon transfer tank this afternoon. I am renting an excavator at the end of the month for a week and it will be 40 miles from the farm where I store fuel. I bought this aluminum tank at a farm auction with a bad pump several years ago for next to nothing and put it in storage. I also bought out a bunch of Fill-Rite inventory knowing that I’d use it eventually. Little bit of treated lumber and pieced together a pump, filter and Veeder-Root out of the stock I bought and some pipe fittings I had stashed away. I’m waiting on a hose reel from Vevor to put on it and debating on a power source.
Well JL Audio overwhelmed this sub. It is DIY project so not original subs that go under the seat in BMW. This one under passenger front seat was always like bit weaker than one under driver seat. Well, on Thursday i have music on (for interested, Money for Nothing was playing) and suddenly cloud of black smoke raises under the seat. In a second I was thinking just fire, but then I hear flopping sound of base, and thinking: “there goes voice coil.”
Made urgent order on Amazon, because “no music, no driving,” fixed it yesterday:
Old:
Amazon birdie brought new one just in time to replace it in the afternoon:
Box that holds BMW sub. As you can see, part has to be cut to take 8” Pioneer. Sound insulation is put on at the bottom to retain pressure:
New one with plastic protection:
New one without plastic protection as it wouldn’t be able to fit in the box with it:
Overall, better. I think old one was problematic from factory as it never had performance of one under driver seat.
The Subaru is nearing 100,000 miles, so I've been taking care of all the work that is due (or overdue). Last weekend was the PCV valve and oil change, then brakes a few weekends before that. This weekend was spark plugs, which were due at 60,000 miles according to the schedule. Whoops. Also whoops is that apparently the NGK plugs I got from O'Reilly's were Iridium IX and not the recommended Iridium Laser. My 50 mile test drive through town and countryside (and freeway) seemed fine, so hopefully the car isn't that picky.
Overall, not quite as hard a job as it is made out to be, but **** these two battery tray bolts in particular (not my image, taken from: https://www.subaruoutback.org/threads/battery-bracket-spark-plug-removal.565816/). They did not get reinstalled.
Only pic I took from the job:
