What are you working on today?
Son to the clown cars Civic nearly crashed it (like said clown car) and decided then was the time to tell me the brakes are loud 🤔
Mhm...
Yeah...
They were allegedly quiet till the grinding started
Ironic it was an outer pad (no AWI)
The inner pads on the Civic carry the AWI, except the last shop that put brakes on this thing put the AWI facing down, instead of up as the service manual states
I wonder if that's why they weren't audible in time 🤔
Bosch Quietcast pad & rotor kit got him right, along with a mild front fluid flush
I've been having good luck with Bosch Quietcast pad/rotor combos
Much better than Raybestos Element3 kits
It also got an OCI and a ATF spill and full
144k on it, that might've been factory ATF that came out 😬
In went 2.5qts of Idemitsu H Plus
I really need to pull the display and resolder
Wound it all the way up to 11mph 😄
He's been advised of the severe control arm bushing wear, that causes odd handling and erratic tire wear
I sent him a pair of the second cheapest tires, I give it a week tops 😔
Did rear diff fluid in the RAV4 today. Noticed a leak of pink fluid from the front end. Did the ATF yesterday and thought uh oh. Luckily it was just a loose radiator cap that inadvertently loosened working on the serpentine belt on Friday. Took me 4 hours for the ATF and transfer case fluids. I found lost tools under the engine and I'm sore today. Good thing that I don't do car repairs for a living.
