Co workers son got a different (take 3?) 2006 Ridgeline
Which lasted all of a month, before breaking down and overheating
'06 RTL with 144k, I believe I pulled the factory radiator
In the parking lot, of the job...
Due to corrosion and time/tool limitations, I bypassed/eliminated the radiator ATF warmer, only the aux external standalone cooler is in play
Luckily one of the hoses is the perfect length for the job, eliminating a time consuming parts run
And before anyone says that I've deprived this BJFA of temperature control, it was neglected before I got a hold of it
It's the least of this things problems
Buy a new cooler line assy if you plan on this job, if it's crusty
Denso Indonesian radiator was used
B/A (Tama Japan) thermostat and a meh Fel Pro (Japan) gasket
It holds temp and doesn't overheat, that was the objective
I might swap the cap for a Calorstat brand, we'll test them out
Also did some other minor nonsense
Keys, keyfobs, PCM reflash for a shift concern TSB, found out why the cruise control didn't work
It's gonna need my standard workup
CAF, OCI, I now preventatively replace all old Honda MAG CLUTCH relays because of the trauma I had of one sticking on and locking up the compressor
$5 for the peace of mind
Needs a door jamb switch, CHMSL bulbs, P/S pump o rings, the rear diff probably has the factory Dual Pump Fluid in it
It gets what they're willing to pay for
It's a premium beater ™
It'll do
It'll do
