Very busy day....
2015 F150 3.5L/6R80, 218,xxx miles....P2111 which was caused by the Throttle Body. Has pretty bad converter shudder....Ran 20 quarts of Maxlife ATF through it, Then changed the fluid & filter. Changed the engine oil.
Got the pistons knocked in the Hemi...No pics.
My 2nd year apprentice got the engine out of a 2014 Nissan Juke 1.6L Turbo.....What a epic mess!!!!
Came in for a check engine light, P0011 (Intake Cam phase issue).
The owner had the Timing Chain replaced, Both VVT Solenoids, Crank Sensor & Intake Cam Sensor between 3 different shops.
Intake Cam was 19-20° advanced....Recommended pulling the engine & verifying the chain installation, She didn't like the labor quote & took it back to the shop that did the timing chain, She brought it back this past Monday saying the shop thinks it's a "computer issue" & the chain was installed correctly.
I demanded half of the labor up front because I've "Been there, Done that" with new customers abandoning throw away cars after agreeing to repairs, Glad I did because it's going to cost a lot more than quoted!!
12 stripped out bolt holes, Belt Tensioner got trashed, Intake Cam Phaser full of RTV, Timing cover has a hole worn through it, Guessing by the original timing chain & was patched with JB Weld.
I can only imagine how much RTV is in the oil pan?
*Intake Cam is 1 tooth out of time.
Priced out installing a used engine with her new timing set & fixing the existing mess, I'll call her Monday as I feel this will get interesting
