What are you working on today?
The Hemi is ready to drop in sans valve covers....
Most of us know these engines are notorious for manifold bolts breaking, I use ARP 8740 on all LS/LT engines....ARP doesn't make a bolt kit for Hemi Manifolds so I measured the originals & came up with 45mm UHL, 50mm UHL ARP 661-1007 is a perfect length. Should work on all '09 & up 5.7L & 6.4L Hemi truck engines.
Tightened the bolts to 21 foot pounds in several passes using red loctite
Stock rebuild or performance upgrades ?
2008 Ford Edge
Replaced cooling fan module assembly, rotated tires, inspected brakes, changed oil
1995 Chevrolet Silverado 1500
Replaced wiper motor pulse board, left front turn signal bulb
1985 Chevrolet C10, the one I worked on Monday
R&I fuel tank to replace sending unit
Stock rebuild with some upgrades.....
5150 steel camshaft instead of a factory cast SADI
Latest updated Mopar lifters
Deleting the MDS
High Volume/Standard pressure Melling oil pump
Clevite tri-metal inserts
SRT 392 valve springs
Engine stabbed in the chassis....
Looks really good !!👍👍 I get emails from Melling listing all the latest and greatest parts they offer.
Do you use a lot of their parts ?
"The classic" (as Eric O would say) blower resistor failure in an '05 Ram 1500
I stock a resistor as I service so many 2nd Gens, and I was pleased to learn the 3rd Gen uses the same resistor.
The motor is of course toast, too. It was a Denso and the truck somehow has 294k on a 5.7 Hemi -- I wonder if the Denso is the original blower motor?
Thanks.
I use Melling oil pumps a lot & some of their USA made timing kits/components. This engine has a Melling timing kit/USA made & the tensioner had a Mopar part number, Melling might be OE for this particular application?
I use their timing sets on 3V Modular Ford's a lot....(With Ford OE Phasers)
Thanks.
Interesting
As an outsider looking in. I’d think Melling parts are high quality
2022 Mini Cooper JCW All4:
-oil change. That is all. But I'm not a huge fan of this no dipstick thing. You're at the mercy of putting in "5.6 quarts" and hoping. Apparently the system can't check oil level immediately? Says you're supposed to drive for 30 minutes? And even then does it supply an actual graduated reading, or just a binary ok/not ok?
I'm a Luddite, I like dipsticks. I'm off to find a rock and smash something.....
I bought Sequoia in November. Did coolant immediately but was waiting for better weather for the differentials, transfer case, and transmission (doing that tomorrow. My wife is about to deliver any minute, so I'm stuck at home, and since the weather is in the 60s, I got bored. Car currently has 71,000mls.
First time on Quickjacks. Wondered how it would work. This is 7000TL, so 7,000lbs capacity. Sequoia is 6000. Works like charm on BMW, VW, I know @Astro14 lifts Tundra with it, but Sequoia adds like 200-300lbs over Tundra. Turns out, no issues. Super stable!
Plenty of space below:
Home Depo pump works like a charm:
Transfer case fluid was black in color:
Like all differentials on my vehicles, this one got Motul Gear 300 75W90. Nothing like strong smell of esters in garage :). In total, the differentials and transfer case took approximately 5.5qt:
Both differentials had a black color and smell of oxidation. No smell of esters like in BMW or VW.
The basket case '05 Ram 1500 reappeared. He wanted the right front fender and front bumper replaced after running into a bollard in the gas patch.
I ordered a new fender on ebay and sourced a better (but far from perfect) bumper locally.
This is some serious backwoods bumpkin Cletus bodywork which I post solely for your amusement. All insults welcome.
Before:
Step into my high tech paint booth. Today we'll be using Rustoleum Pro in a rattle can:
Old fender away:
When the factory plastic license plate square nuts inevitably break I like 1/4‐20 nutserts:
After:
Original 5.7 Hemi sounds like a diesel mixed with a choo-choo train combined with a ghostly rattle of chains....but it runs. Somehow:
Beautiful work on a wonderful car. I love my Quick Jacks.
I’d encourage you to place a set of jack stands inside the quick jacks, one on each end. My 3 ton stands extend just below the max extension of the quick jack.
Before:View attachment 265789View attachment 265790
Step into my high tech paint booth. Today we'll be using Rustoleum Pro in a rattle can:View attachment 265791
Old fender away:
When the factory plastic license plate square nuts inevitably break I like 1/4‐20 nutserts:View attachment 265793
After:View attachment 265795View attachment 265794
Original 5.7 Hemi sounds like a diesel mixed with a choo-choo train combined with a ghostly rattle of chains....but it runs. Somehow:View attachment 265796
No judgement from me. Looks good imo.
Old fender away:
I quite enjoy this saga. The Ram soldiers on!
