Replaced the rear brakes on my mom’s 2015 Mini Cooper.
I’d ridden with her and could hear grinding from the rear brakes. She assumed rust on the rotors since it’s driven infrequently. And, the brake pad indicator hadn’t lit up so she didn’t think they were worn.
Fortunately the rear brakes on this car are small so they were $100 from RockAuto shipped. Geomet coated rotors and pads with hardware.
Getting the parts off was relatively easy; even the rotor retention screw came out without issue. But - the caliper bracket bolts are E-torx (E16 to be exact) and are situated in such a way as to be obscured by the shock and the caliper (which is still attached to the parking brake cable and can’t be hung out of the way without more disassembly; better to leave that alone). And, they were tighter than my breaker bars, if they could get in there, could break loose.
My E16, on an adapter from 3/8 to 1/2, on a swivel adapter attached to a long extension run by my Hercules 1/2” impact managed to get all 4 bolts out without damage. Not a great design.
Why no worn pad alert? The right side caliper has the brake pad wear sensor and it hung up on that side. The outer pad (and also the pads over on the left side) wore down to the backing plate. The inner right with the sensor did not, so no light.
Greased and checked the slide pins to be sure they would work, new wear sensor, and resetting the computer to put the pads at 100% again. Test drive went perfectly. I love it when it works out, even with the little challenges.
Then I changed oil and filter on my nieces 2008 Ford Escape. Not much to relate there, other than the place she bought it from recently didn’t have an air filter in it.
. We put a new one in, but I’ll be monitoring it and doing another oil change very soon.
