First rear brake job on the 2004 Focus at 208,000 miles. Strange how Ford manual wants you to remove four bolts behind the backing plate to remove drum and spindle as an assembly. No mention of removing the drum if you wanted to replace it so no info on a torque value for the drum. Passenger side went fine while driver's side had a leaky cylinder. Now I had to call around for one as I had everything except a spare wheel cylinder. Shoes were NOS Ford as originals lasted so why change. Also re-used springs as the generic springs fit poorly. This Wednesday the manual transmission fluid and then the tie rods on the 91 626.
