What are you working on today?
I’m doing everything except oil on my new-to-me 2012 RAV4. I had to go back to AutoZone because they gave me the wrong plugs and I didn’t check the number until I started installing them and noticed the plugs I was removing were significantly longer than the replacements. Imagine if it had been the opposite and someone started it? Somehow I doubt ol’ shakey behind the parts counter would have wanted to spring for new pistons when the wrong plugs punched through them. I had ordered the correct plugs but he had pulled the wrong ones off the shelf.
After getting the correct plugs I broke my fluid pump filling the differential. I still have ATF, coolant and the transfer case to do tomorrow.
The clutch failed on my mates VW T4 Syncro. We had a look and decided it's too hard to do on his gravel drive, too expensive to put into a shop, but also too much money to dump it and get something else. so, we decided to go for it and pulled the engine and gearbox out the front. This was last saturday, so now he can source parts.
Not too bad, just a crack in the pressure plate and the flywheel in half with a 3rd crack. It's going to be even more fun getting it back together.
Took it easy this morning and did a big Surplus Center order for my equipment trailer. I’m building a gas power unit to run the hydraulic ramps and eventually a winch.
Went and bought a 1949 Farmall Super A from a family member this afternoon. It had been stored inside an enclosed trailer for several years so I took the skidsteer along to recover it and load on the utility trailer. Gotta get a couple front tires, battery and clean the fuel system tomorrow and I think it’ll run. I grew up around this tractor and it’s one of the first things I “drove” as a toddler. I have no real use for it but I want it to stay in the family so it’s been added to my collection. I’ll care for it and hope there’ll be someone else to appreciate it when that time comes.
I think every kid should have to learn to drive on a manual transmission (ie not HST) tractor. If you can drive that, you can drive most cars and light trucks with ease.
I agree but millions are stuck living in cities and places like that.
  • Wow
Reactions: D60
Piddled a bit more on the Polaris Magnum. I am limited on what I can get accomplished, about a week out on getting the new seals.
I tored down the left side front end, supported the ball joint stud as I tapped the A arm off. Then proceeded to rip the stud out anyway with the ball joint removal tool. I welded it up and removed it. New joint knocked in.
Of course the roll pin for the left front CV shaft is at an awkward angle and in there solid. The roll pin for the front driveshaft kept working its way loose so it was replaced. The steering shaft nut was tightened. When I had it out last, I left it too loose. Now with the front end torn down, it was easier to get right.
Monday I have to call napa and hope they have another speedi sleeve in stock somewhere. The left side hub sleeve has wear grooves. When I ordered the one, they had nothing in stock anywhere.
Beat the marathon 🏃‍♂️ traffic in and out of work this morning for some OT
Ran home, fought the stolen hour of light from DST 🙄
OCI on a '11 Avalon, it was overdue
Rear pads and rotors on a '16 Fusion, they were down to the backing plate
And the future BILs Soul he bought from Carvana arrived, an emergency dashcam install was performed to protect the investment
Did some fall cleanup in the shop. Consolidated some pails of oil, which allowed me Consolidate some used oil jugs. Hopefully I can get that to the transfer station sooner than later.
I loaded up the clown car with the radial arm saw and belt sander. They went into storage. This gave me more room to work on the quad and not get in the way of the skid steers.
Then hauled in several loads of sand for fresh footing in the indoor riding arena. Leveled it out with the 318G.
Sunday I got the Sonoma pulled into the shop, greased the steering and suspension, checked everything over. Little bit of play in the steering arms but nothing I'm too concerned with. The front wheel bearings will need to be repacked, when I do that I'll probably turn the front rotors and replace the pads. Something to do some other time.
Yesterday at work I faced some factory style Ford super duty front CV driveshaft joints to our modified specs, then started a batch of aluminum steering links.
On the CV joints, I cut the driveshaft off a few inches behind the weld, just ahead of the front counterweight. The actual face of the CV is faced down from ~ .4.97" to ~ .3.75", .060" into the joint. Picture attached showing the part I modified.
From the last few weeks:
14 ES300h, 125K: LOF, Rotate Tires
07 Accord, 172K: LOF, Rotate Tires, Air Filter, Cabin Air Filter, ATF drain and refill
25 TX500h, 5K: Rotate Tires
03 Accord, 141K: Replace Flex Pipe w/gaskets, ignition switch, wiper blades, top-off engine oil
19 CR-V, 62K: LOF, Rotate Tires, Brake Fluid Exchange
25 Forester: 9K: LOF, clean cabin air filter
10 Civic, 150K: LOF, Rotate Tires, Replace RF Caliper Lower Slide Pin, Cabin Air Filter, ATF drain and refill
08 Eclipse, 201K: Timing Belt, Balancer Belt, Water Pump, Tensioner Pulley, Idler Pulley, Timing Belt Hydraulic Tensioner, Balance Shaft Tensioner Pulley, Serpentine Belt Tensioner and top-off engine oil.
2011 F350 6.7L Powerstroke/6R140, 340,000 miles. DTC P0088 rail pressure high.
*Pulled the flow control valve (End of the left fuel rail), Didn't have any metal on it but the tip had some erosion. OE Ford/Bosch valve fixed the P0088.
*Changed both fuel filters
*Transmission & Transfer Case service
Needs cab mounts BAD....It's like driving a seesaw;), Upper oil pan is pouring, All ball joints are loose & the rear shocks are blown. Customer declined these repairs.
2001 Silverado 5.3L/4L60E, Rubber sections of the transmission cooler lines were leaking, Cut all the crimps off with a cutoff wheel & ear clamped in some good reinforced TOC rated hose.
'11 Duramax: new Bilsteins all around, new OEM thermostats (P0128 and a max water temp of 157), new OEM block heater and cord
This poor truck turned into a mini-saga. First, they asked me to fix damage to the block heater cord. I had actually ordered a new aftermarket cord, but it came a day late. So, wanting to just get 'er done, I repaired the cord. I plugged it in in my shop and it made the standard popping and growling noises, so I declared it good.
In hindsight, repairing a block heater cord probably wasn't great from a liability standpoint, but I was working with what I had available because parts were late.
They got home and told me it was "popping the breaker." In pulling more information out of them, I think they meant it was tripping a GFCI, which is different but most people don't understand.
Either was I was mortified because I don't like comebacks. I apologized profusely and said I'd make it right. They said no problem, and order some new shocks while you're at it.
I ordered an OEM cord on ebay (note: it's kinda hard to fake these because OEM gets heat shield tape while aftermarket is just a cord) with the CORRECT part # but received a cord with a slightly narrower plug -- something for a different GM application.
So I called my dealer, gave 'em the last eight and just bent over. $117 later an OEM cord arrived the next day.
In the meantime I had run some basic checks on the cord I repaired. There were no internal shorts, and resistance on each line was zero ohms.
Nonetheless, I plugged in the new OEM cord, chased down a (two, actually) GFCI, and it still tripped. So, I informed the client it's gotta be the heater. Fortunately I had an OEM heater on the shelf.
Replacing the heater isn't a bad job, but definitely a bit of a game of Operation. On the LML it's obstructed by the engine oil dipstick tube. I removed all three bolts that anchor the dipstick and then kinda pried it away from the block.
These mixing trays sure are nice for draining larger quantities of [fill in fluid].
I put everything back together, filled with fluid, and confirmed nothing was tripping a GFCI (YAY!). I was about to tell the owners to come get it, but wait -- it couldn't be that simple. Now the lower rad hose was leaking after having been disturbed to drain the system.
These hoses can use two different possible o-rings. A new hose is ~$200 aftermarket on RA and ~$300 aftermarket B&M (even on commercial accounts). Dorman seems to know this because they offer a single o-ring -- but only for the later, updated hose -- for $20 retail or $14.50 commercial. It's absurd but they KNOW when weighed against a new hose, you'll pay $20 for a $1 o-ring.
Dorman offers no help or guidance on what to do if your lower rad hose is factory OEM "not updated" as this should use a different, thinner o-ring. Searching the web and YT netted a result of Fel-Pro 35705, which was under $2 on my O'Reilly account (and $0.89 at RA). I ordered both so I was ready, and this hose wound up taking the thicker, red/orange, overpriced Dorman. Whatever, it doesn't leak.
Replacing the o-ring:
Then, I put a TRD shift knob in the wife's new-to-us '15 Tundra. If you have to shift, reach for the TuRD!!
Mostly link bars this week at work. I've been driving the F-150 every day since last Monday. It's had a miss when cold and then under light load hot, scan tool cylinder contribution test showed cylinder #5. I had a few spare Ford 2v coils in the shop at home, so I planned on replacing it Tuesday night. The engine has been bone dry, but I noticed some crusty residue at the front of the intake manifold. Pulling the #5 coil revealed a spark plug completely submerged in coolant....but I have no idea how long it's been that way. I blew out the tube, checked the plug for tightness (#1 was blown out when I got the truck, this one was still good and tight) and socked the replacement coil on. Skip fixed. Still no wetness from the intake so I'm just driving it and keeping it monitored. Also seeing no visible coolant loss in the degas bottle, added about half a gallon when I first got the truck back on the road. Other than that, it's hit the road quite nicely for a 304k mile, 21 year old Ford F-150. No complaints.
after a trip to Menards I had my glass hatch decide to close on my head after giving me no heads up ;) the struts were failing prior to the head bang...
a quick visit to RockAuto.com and I bought new STRONGARM struts for the glass hatch as well as the hatch door itself...
the wallet is about $50 lighter but the struts seem to work great and were easy enough to install...
Bill
