Yes with this club a few times. I've got about 15 days at VIR.I expect to hear all about your time at VIR when you are finished. Have you done the HPDE before?
Yep its definitely a HST. I hooked up a remote starter button this afternoon and it turns over and sounds like it has compression, but no power to the secondary starter cable so there is definitely a safety switch broken somewhere. I'm really good at mechanical stuff but novice at electrical, but electrical is starting to make sense in my brain now. I'm also not getting any fuel, so about to change the under filter and possibly swap the fuel pump. I might drain the entire tank as well while i'm there just to see what the original complaint from the seller was before it ended up in pieces by his mechanic.My HST won't start if it even thinks the foot rocker isn't in N. Dunno if yours is HST?
Well this rotor ring swap out went south in a hurry. Accidentally set the wrong torque for the BBK caliper to bracket bolts and whoopsie! 90 ft lbs instead of 74. Lucky my trusted shop got it helicoil'd so I can hit the track this weekend. Timecert is the better fix but they didn't have one im the right size so this will do with a check during each day to make sure it's good.
View attachment 191985View attachment 191986View attachment 191987
Rotor is just steel like any other.Wow. Seems a little interesting the centering would be like that.
What material is the rotor made of?
Pics look so black. I need a new monitor!Rotor is just steel like any other.
The bolt pattern area looks so different from the contact surface. Looks like a coating.
Ah sorry man! That just have a coating....already off.The bolt pattern area looks so different from the contact surface. Looks like a coating.
