Oil change on wife's Juke. Lowered to 4k OCI. It's starting to use a bit of oil. Just over 155k miles. Hope it last another few months before replacing it. She has a long commute and she's tired of it and a manual Trans in traffic
You mentioned the slippery feeling if the 132, I've noticed the same thing with Swepco 306 oil. When I check the oil in my truck, even after 7000 miles if any gets on my fingers it's difficult to just wipe away with a rag. Very slick.Changed the oil on the Mack today and got it all greased up. Also had a couple cracks in the subframe for the cylinder mount so I ground them out and repaired them and shot some new paint over it. That gallon of Schaeffer 132 in the engine oil really makes things a slippery mess when you go to drain it. The stuff literally sticks to you.
Tonight we went and looked at a fence clearing job that will start tomorrow. I’ll move what I can with the skidsteer, grapple, and tree puller tomorrow and move the track loader in to finish what little the skidsteer won’t be able to do.
Your welds look immaculate.Changed the oil on the Mack today and got it all greased up. Also had a couple cracks in the subframe for the cylinder mount so I ground them out and repaired them and shot some new paint over it. That gallon of Schaeffer 132 in the engine oil really makes things a slippery mess when you go to drain it. The stuff literally sticks to you.
Thank you! I’m no professional welder but I can get it done.Your welds look immaculate.
Pfft, amateur! I can take a one-hour job and somehow make it take 8 hours per day for two consecutive days. I win.I'm sure I'm not the only one, but I can take any one hour job and turn it into a 2 hour job over 2 days.
I finally got the clamps and lube to take care of the 'Ford Slip Yoke Bump' that pretty much any Ford vehicle with a 2 piece driveshaft gets over time. The first time I did the job (a few years back), I noted that the middle slip yoke is keyed, which is nice so you don't have to pay super close attention when you put it back together, so I thought.
Yep, they're keyed alright, but they can still be flipped 180 degrees out from each other. So while you don't have to pay super close attention, you should probably still make a mark on the boot and shaft so you don't put them back together 180 degrees out from each other.
Guess what I managed to do.
Luckily, when I bought the boot clamps, I bought 10 of them, so back under the truck, the next day, I go to fix the screw up.
The vibration from being out like that wasn't terrible, between 40-55 mph it was more of a very slight grumble, but normally my tuck is completely vibration free, so I noticed it immediately.
Ohh well...
And yes, I know Ford calls the 4 driveshaft bolts a disposable part and you're supposed to use new ones. Likely because the threadlock they put on them really should be replaced. They're not TTY, so cleaning them up on a wire wheel and reapplying some threadlock will do the job just fine.
