Which ACEA sequence, either high saps A5/B5, A7/B7 or the low/mid saps seq C5/C6 would be more similar to a Dexos1 Gen2 say in a 0w20 weight?
To put it another way if an application called for a Dexos1 Gen2 0w-20 spec oil, which ACEA category:
A/B: Gasoline and Diesel Engine Oils – “High SAPS” or
C: Catalyst & GPF/DPF compatible Engine Oils for Gasoline & Diesel Engines – “Low/mid SAPS”
would be closest to Dexos1 assuming both were 0w20 weights?
