Ford dealership here in Fairbanks has a sign posted on the counter at the Fast Lube shop. 5w30 used in gasoline engines, 10w30 in diesel engines. They use Motorcraft oil.
quote:Show me one engine failure caused by 5w20. Show me one bad oil analysis with 5w20. I'm waiting. [ December 22, 2002, 12:20 PM: Message edited by: Patman ]
Originally posted by metroplex: 5W-20 is used for CAFE/EPA not engine longevity. I don't understand why no one frigging understands this.
quote:Anyone know for sure???
Originally posted by Mike: Can they determine the original viscosity and oil brand from an oil analysis?
quote:Mike, the issue isn't them proving the oil you use was not API certified, you have to produce reciepts of oil you purchased for the vehicle, and then they will know without any analysis whether or not the oil is API certified, and whether the proper viscosity was used. The burden of proof is upon you that the vehicle was serviced properly. Then the burden of proof switches to them to prove that the failure was caused by something you did.
Originally posted by Mike: TooSlick You say you can tell but I want to know if it can be done with certainty? Not just from experience. All this hype about non-api oils voiding warranties makes we want to know if they can prove it. I inquired of the analysis people but they have not or will not respond.
quote:Honda is also known for building high mpg cars and they don't want to lose that reputation either. So their motives aren't as simple as you make it sound. Most people are happy with an engine lasting 150,000 miles, and 5w20 will do that job. I'm interested in how long an engine CAN last. I read an article where Ford was happy with the engine lasting until 150k with 5w20 so that was good enough for them . Car companines are shooting for a target that's acceptable by the market, not for a target that is the BEST. Just my $.02
Originally posted by tenderloin: Honda is not up against any CAFE numbers. Although they are known for high mileage vehicles, IMO they will not PI$$ away their well deserved reputation of building quality dependable cars for a half mile per gallon or so. Get real.
quote:I drive a 1999 Surburban K2500 at work for the last 4 yrs. Had the oil changed every 5000 miles. Nowhere on the receipts did it say anything about the oil being API certifed, so how can that have any affect. Everyone here appears to be changing thier own oils, how are they proving it API. I see Amsoil selling in Walmarts, parts stores, ATV stores, service stations, GM Dealers etc. I was told some time ago by a GMC service manager that I needed to prove maintanence is a log of the date, miles and what was serviced.
quote:If you had it changed at a dealer or reputable business then the warrantee company isn't going to raise an issue of oil grades most likely. This is mostly an issue with those that do it themselves. Everyone concerned about warrantee coverage should keep a receipt and a log of the work they did in my opinion. In reality, I doubt any failures will be attributed to the oil if changed within the recommended service interval. For those running extended drains, I'm sure that will raise some questions with the warrantee company if there's an engine failure. That's not to say they won't cover it if you have good records and oil analysis to back you up. [ December 23, 2002, 04:19 PM: Message edited by: Giles ]
Originally posted by Mike: [QUOTE]I drive a 1999 Surburban K2500 at work for the last 4 yrs. Had the oil changed every 5000 miles. Nowhere on the receipts did it say anything about the oil being API certifed, so how can that have any affect. Everyone here appears to be changing thier own oils, how are they proving it API. I see Amsoil selling in Walmarts, parts stores, ATV stores, service stations, GM Dealers etc. I was told some time ago by a GMC service manager that I needed to prove maintanence is a log of the date, miles and what was serviced.
quote:Thanks TooSlick, Finally, someone offers a rational explanation of why 5w20’s work OK. Beef up the oil pump. As TS suggests, that’s not a fix-all, the add pack needs to be up to the challenge.
Originally posted by TooSlick: If you simply increase the output of the oil pump, you can get excellent oil pressure even with a 5w-20 oil under heavy loads. So main bearing wear isn't really an issue ... The challenge is making a 0w-20/5w-20 oil that provides protection for the valvetrain, where you are operating under a "mixed mode" or boundary lube kind of situation. How you do this while decreasing the # of ZDDP will be interesting to see? That's where esters and/or MoDTC may come into play.
quote:Metroplex, Let us all try and finally put this to rest. I have the service manuals for all Ford Models 95-2001 (95-2002 for the Trucks I think) and can look up the tolerance specifications. Each model year, I have to burn on CD, which I am in the process of doing. Sooooooo...what factory tolerance specs are you all interested to see? Regards, Oz
Originally posted by metroplex: 5W-20 is used for CAFE/EPA not engine longevity. I don't understand why no one frigging understands this. FACT: 2000 Mustang GT, 4.6L SOHC V8, WINDSOR PLANT ENGINE. Ford spec's 5W-30. 2001 Mustang GT, 4.6L SOHC V8, ROMEO PLANT ENGINE. Ford spec's 5W-20. Ok, so you say that the Romeo plant engine is built to tighter tolerances? 96-98 Mustang GT, 4.6L SOHC V8, ROMEO PLANT ENGINE. 99-00 Mustang GT, 4.6L SOHC V8, WINDSOR PLANT ENGINE Main differences: 96-98 GT had non-PI heads while 99-00 GTs had PI heads on a Windsor made block + rotating assemblies. I have spoken to Ford engineers re: this and they state THERE IS NO NEED TO USE 5W-20. Heck, there are no differences in the 00 and 01 GT engine that would call for THINNER oil!!!! Just use 5W-30 where it asks you to use 5W-20.
