- Joined
- Nov 29, 2009
- Messages
- 7,290
How can I fix this. I periodically have to add 3-4 ounces once every couple months. I thought it was the oil that ate through the Teflon tape cause I didn't use the yellow kind. I had someone weld a temp probe on a couple years ago to avoid leaks. (go figure) Can I put a dab of JB weld on it? Or can I put a dab of rtv sealant on it? Worked for the transmission pan I don't see why it wouldn't on the weld. Or can I just have the guy tig weld that one spot with the pan on?
