Hi all,
My dad and I worked on my 1997 Chevrolet Cavalier to get it to pass emissions which it failed a couple of weeks back, ( which I posted). We replaced the plugs with the exact same Denso Iridium spark plugs that were in it ( same part numbers.) I noticed on the firewall that it recommends a spark plug gap of .060 which seems like alot. The new Densos were .030 but was told not to gap those. New wires, new radiator as the original was leaking, new overflow bottle and hoses. It seemed to run smooth early on. I went up to the gas station to fill up and add Cataclean to the tank. It started to sputter at idle and had a mis while driving setting two P0300 which are random misfires. Usually after a tune up your vehicle runs great. I did check the wplug wire order and that was correct. I'm wondering if I got a bad plug or wires?
