WD40 o rings ?
Ndx
IL
Hey Guys,
Anytime I have to slide something with o ring I will lube it with WD40
A) it will not migrate like let say vaseline but it will evaporate
WD40 website says safe for rubber
I seen some diy test where orings were not affected after seating for 24hrs
Should I replace orings that I used WD40 on ?
Or not worry about it ?
Originally Posted By: Ndx
Hey Guys,
Don't worry about it...anything is better than nothing and WD-40 is harmless. Personally, I use Vaseline. Vaseline melts at about 100*F and I have not noticed any mess. It disappears very quickly around a hot engine. Never had a seal/lip or "O" ring leak with Vaseline..(knock on wood)
I've used motor oil on gas line fittings and the appropriate fluid (PS, ATF, etc) on everything else.
Probably too little to make any difference.
Thx, should I replace them then ?
According to WD40,neoprene is not affected by it...
For all variations : WD-40 demonstrates none to negligible deleterious effect to plastic, rubber, and metal hard surfaces. This includes Acetal, neoprene/hard rubber, HDPE, PPS Copolymer Polysulfone, Teflon, Viton, steel, galvanized steel hot dip, electroplated, copper, brass, magnesium, nickel, tin plate, titanium, and zinc
According to msd there are some rubbers that will swell after prolonged exposure... Orings are pretty tight sealing stuff so I wonder if it will evaporate or because its tight its just gonna sit there ?
