I wouldn't pump it up to 30 psi. Maybe 20 at the most.
I have only seen one of those pumps leak from the weep hole. They often leak from the gaskets between the block and the water pump.
The Napa pump if you need a pump comes with all the necessary parts. The others only have the water pump and the 2 block to pump gaskets. So then you must go searching for the other gaskets for the thermostat housing or use silicone on the old one.
Once you get the intake boot and fan shroud off you must remove the big nut that holds the fan clutch on.
Then remove the upper and lower hoses then the 2 small heater hoses. Now remove the six bolts with 10mm heads and the pump will fall off. Be care full that you don't ding the radiator with it as it's pretty big and awkward.
That's it. It's that easy. Clean up the gasket surfaces and reinstall the new parts.
As I already said I have only seen one of those pumps leak and it had over 200k on it. Since cash is tight you may be able to get away with just replacing the 2 inexpensive gaskets instead of the whole pump.
