My 2001 Dodge Dakota has 132,800 miles on it now. 3.9 V6 and a 5-speed manual. About 6 months ago the fan clutch siezed and I replaced it. Everything is fine, there are no water pump bearing noises, no play in the water pump shaft and my truck runs cool even in the 100+ degree heat here in Florida. Last night I read online that the water pump and fan clutch "usually have the same life span" and it is recommended to "replace the water pump when you replace the fan clutch, because they both last about the same length of time".
I bought my truck used with 41,000 miles on it almost 5 years ago. In the time I have owned it, I have had the coolant flushed at about 60,000 miles, then at 80,000 miles I hit a deer and the body shop had to replace the radiator so it got new coolant again. Then at 129,000 miles on March 31st this year I was hit in the front end and now I have another new radiator, a new fan shroud, a new AC condenser and another fill of new coolant.
The way I learned it is as long as you flush the coolant on a normal schedule (or in my case accidents caused me to get new coolant and new radiators twice) the water pump should be fine and last a very long time. I learned that the lubricating properties of coolant keep the water pump lubed, clean and in good condition, so unless the pump fails or starts to leak, it is best to leave it alone.
Anyone else heard of the "replace your water pump when you replace the fan clutch" theory? What do you guys think?
