Water Wetter
Ind
Would there be any advantage to putting the Redline water wetter into a new toyota with the toyota pink antifreeze? Would it do any damage to the system?
toyotaguy
Ind
so will this product actually decrease the operating temp with use of the toyota pink coolant
Central Coast, Calif.
the thermostat will bring the temp right back up. There is no reason and no benefit to running water wetter in a stock vehicle with standard coolant. read the bottle, best case scenario it drops the temperature 2-3% when used with 50/50 coolant.
toyotaguy
Ind
from what I am reading is a benifit would be that it helps to remove hot spots. Would this be correct?
