dnewton3
Staff member
About 3 weeks ago, I went downstairs and found that the water heater had relieved pressure; water all over the floor and even up on the walls near the location. I assumed that either the T&P was bad (most typical cause) or that the gas valve had stayed on too long (less likely, but possible). So I replaced them both. The tank looked good inside from what I could tell; very little debris or sediment. I used a lit match to check the smoke trail and made sure the vent pipe had a good updraft. Seemed fine after repairs, and so thought nothing of it.
This morning, the same thing happened. I was on the computer and heard the rush of steam and pressure. Ran downstairs and saw this (photo 1).
Now I'm perplexed. I am digging deeper. So I pulled the angled vent pipe and looked up the exhaust; it's clear as a bell (photo insert 2). I can see very good daylight at the top. I also went outside and checked the vent pipe above the roof; no damage or obstructions. The angled pipe is also clear; can see reflected light from end to end.
So, even after confirming no vent obstructions, and replacing both the T&P and gas valve itself, the failure mode had reoccurred. We've lived here for 8+ years and never had an issue until now.
I am at a loss ... Any suggestions?
