We just run a 2.5”x20” 5 micron sediment filter and a Kinetico softener. The filter comes out rust red, but everything else is fine assuming I don’t forget to put salt in the softener.
There are 2 types of iron in your water, insoluble ferric and soluble ferrous iron. Insoluble iron you can see right away as discoloration, soluble iron will look okay at first but can eventually start staining stuff like your toilet or shower.
Opinions needed for a system- moving to a house with well and septic for the first time. Water quality test reveals high Iron and turbidity.
Should I go through a plumber, or do you have a favorite?
I'd put outside water pre filter. Why filter stuff going out to the garden? Although I guess some of you wouldn't use anything but the finest filtered water for washing cars.
I've heard of shocking wells but so far, so good. We'll see on this new to me system. But the prior house, nearly 15 years and I never touched the system, and it tested just fine when we sold it (and when we bought it too). Maybe it's a regional thing, some areas need it, some don't. YMMV, as they say.
I have a 600 ft well and I suggest putting in a bypass to whatever filter you get.
Why? No matter the micron filtering level when you need to wash your car or power wash your house the filter can't keep up.
It kills water output. So I run my big 5 micron filter but when I need a high volume of sustained water I turn a few levers and go around the filter.
When I'm done I switch back to filtered water.
Yeah but here they did everything filtered. Everything. Huge filter but very restrictive. I think because they had numerous outdoor animals.Most people put the outside faucets before the filter,
if you dont know anything find an expert.. preferably one that doesnt benefit from selling you as much gear as possible.Opinions needed for a system- moving to a house with well and septic for the first time. Water quality test reveals high Iron and turbidity.
