This is what I used, available at Lowes.
https://www.lowes.com/pd/LiquiVac-Oil-Change-System/1016407
Unfortunately you'll need to use some adapters and buy some small diameter hose that will fit through the spark plug holes. Another option is a syringe available at pharmacies like this:
You can hook tubing to it and stick the tube into the cylinders. You can get them at Walgreens.
