- Joined
- Jan 6, 2005
- Messages
- 10,327
This evening, I did a water de-carbonization treatment on our '97 Expedition with 120k miles.
The main reason I did it was to see if it would make any difference in the pinging that the Expedition exhibits under light load. It doesn't ping much at all under heavy load.
The container I used was a 20 oz. water bottle. I filled it up with distilled water. Here is how I did the rest of the procedure:
Removed the vacuum line from the brake booster.
Started engine (Engine was already warm; if it matters).
Held the water bottle close to the vacuum line.
Let the vacuum line suck ONLY A VERY SMALL AMOUNT OF WATER AT A TIME.
Any time the idle started to drop, I eased off the water for a few seconds.
It took me approx 20 minutes to use all 20 oz's of water.
When water was gone, I re-attached the brake booster vacuum line, & took the Expy for a test drive.
On my test drive, the Expy sputtered a little for a half mile or so. Then it settled down, & the pinging seems to have eased up. It is not gone, though. The biggest difference I noticed is that the tail pipe is spotless on the inside now. I wonder if it did any good in the cylinders.
Fuel system treatment is next to try & get rid of pinging.
