10k mile drain/refills on my GM tranny; this truck currently has 191k miles original transmission with no hick-ups. Truck sees a mix of everything, including steep mountain passes, with living in Colorado.
The fluid that I'm currently draining right now, is still very very clear, red and smells perfectly normal. When I do a drain/refill, i'm only replenishing 3.5qts or so of the total 9.1qts the torque convertor holds...so I figure every 10-15k miles is good...but I'm not wasting fluid either am I?
Truck calls for Dex III, I've been using Castrol Import/Domestic ATF non-synthetic IIRC
