Washer Fluid price increase at Walmart
Stop kveching and make your own. Unless you experience prolong sub freezing temps this works;
1/2 gallon tap water, distilled if you are persnickity
2 gtts. blue food coloring
1,2 gtts. Dawn dishwashing soap
1 pint of isoprophol alcohol, 50%, 90% works better if freezing temps are likely
And by the time you spend almost $3 on 91% alcohol you're most of the way to just buying the stuff off the shelf that's like 25-40% methanol that you know has the freeze performance you need.
Get it at Home Depot. Around my area it’s cheaper than Walmart
