Ok... here's the deal... as some of you may already know- I have a 2001 Suzuki swift, I bought it a few months ago with 53k on it. I brought it home, changed the oil- put in some castrol 5w30 gtx for a short run. after about 2500 miles, I switched it over to Mobil 1 EP 5w30, I intend to continue using this oil. Girl friend swears it runs smoother and stronger with this stuff...(she is primary driver)
I was changing my 95 isuzu rodeo(175k) over to GC tonight, and decided to pull the swift in the garage to check on consumption and have a peek inside. consumption on the previous change was nadda- over 2500 miles not a drop lower on the stick- the EP seemed to loose an ever so slight amount after 1k (1/10th a quart or so). While I had the hood propped and was looking around- I pulled out a flashlight and had a look down in the hole.. uho. SLUDGE.... really worried now- has me thinking that the previous owners probably neglected oil changes.
So I started poking my finger around- more sludge. was was able to pull up some globs on my finger off of one of the "towers" that the cams run through....
So... I've got the rodeo- with the infamous tick- some folks on the board here suggested arx, some folks actually having totally eliminated their ticking with the arx, AND I have this suzuki with signs of sludge. I decided to break down and do it...
I placed an order tonight for 6 bottles of arx(it's cheapest per bottle that way).
I plan on removing the valve covers of both vehicles, taking pictures, reinstalling the covers. Adding arx, following the recomended proceedure, and after the final rinse is complete- I'll remove the valve covers again and post pictures of the results. (and of cource- include whether or not the ticking goes away, lol)..
question... I just put GC in my rodeo- I have heard that I can do the clean phase with synthetic, but not the rinse- is this true? Same thing with my swift- It has the Mobil 1 EP in it now- would like to do the cleaning phase on this oil, and then switch both vehicles over to some cheap dino (probably havoline or maybe just supertech 5w30) for a short duration rinse phase... might repeat if neccessary.. i'll have plenty of arx on hand for repeats and maintanence doses.
I've got a fair amount of the supertech here already- any reason I shouldn't use it for a rinse phase?
Anyone else heard of the little 1.3L DOHC suzuki motors being sludgers? or is it most likally the result of pevious owner neglect?
