I am looking for guidance if is would be safe to use a Warner PH2850 on an application that calls for the common PH8A/FL1A? I have several of the Warners that I'd like to use up. From what I am able to figure out, the 2850 and PH8A are identical except the 2850 has a higher bypass rating (30 psi verses about 10 psi on the PH8A).
I also understand that the bypass valve will only come into play once the filter is clogged/saturated with dirt, so if I use these for 3K OCI's I'd be fine?
