Walmart employees should be inspecting the containers for broken seals when the product is returned, and that would put the fault in their hands as well.This situation is created by low life Walmart shoppers, not by Walmart.
Its not walmarts fault...check before you buy....that goes for any store...Title should be Walmartian not WalMart. Scumbags.
Were the little plastic tabs on the top broken? I may start taking the lid off before I even go to the checkout.Of course, I don't have the receipt but I'll try to return it anyway.
I am in the middle of an oil change, go to open up the 2nd of my 5 quart jugs of M1 5W-30EP and find the cap seal is broken and 100% of the foil seal is gone.
To compare the two jugs, I noticed they smell different, and a drop of oil from each of the 5 quart jugs placed on clean paper shows very different drip rates. The good bottle of M1 drips down slowly, the other quite fast. They are both the same amber color.
From now on, I may purchase the 12 quart box of oil with spigot. I don't think scammers can swap out the oil in that quite as easily.
I should have checked.
Yes, the plastic cap's 'tamper-evident' ring was not attached to the cap. All the tabs were broken. One I removed the cap, the foil was also missing. Unfortunately the ring does not move down like it might on other containers. So it appeared sound until I started to remove the cap.Were the little plastic tabs on the top broken? I may start taking the lid off before I even go to the checkout.
Well, at least we know that Supertech oil is good and won't do any harm if this happens to us. I would imagine that's the oil they swapped.
I use SuperTech HMFS 5W-30 for that reason. It's spout protection is the most secure.Of course, I don't have the receipt but I'll try to return it anyway.
I'm trying to remember, but I'm pretty sure I had one without the aluminum seal but the rings were tight and unbroken. They clicked and broke loose when I opened it.Yes, the plastic cap's 'tamper-evident' ring was not attached to the cap. All the tabs were broken. One I removed the cap, the foil was also missing. Unfortunately the ring does not move down like it might on other containers. So it appeared sound until I started to remove the cap.
Both 'tamper-evident' seals were broken.
I purchased Bissel rug cleaner agent that was basically used and watered down from Walmart. Very frustrating.What kind of toilet skid mark goes through all the effort of buying a cheap oil and higher end oil then pouring both out then swapping it and driving back to the store to waste their gas to then waste time in those long return lines and get a refund for it? goodness I hate some people.
If you go to Costco, you can get a double chunk chocolate cookie or a chicken bake.Been purchasing oil and filters at wal mart for many years....Never an issue.. I always check them before I purchase too...that said at any store...
I've never had an issue with filters, either. And I really don't think I ever did with oil seals until now. But it seems to be a thing these days, so time to start checking.Been purchasing oil and filters at wal mart for many years....Never an issue.. I always check them before I purchase too...that said at any store...
