South KoreaWhere is SK?
@61.95 is that 2.5X better than the Castrol product?Perhaps worth doing a google search for Ravenol SMP 5w30. Comes with BMW Longlife-04,
MB 229.51, Porsche C30 and VW 504 00 / 507 00 approvals. Similar to Ravenol VMP, but less
expensive. Probably majority group 3 instead of group 4/5. I have no clue why Blauparts sell
VMP but no SMP, even though it's listed at Ravenol America.
https://www.blauparts.com/vw-motor-oil-504-00-507-00-5w30-vmp-5l.html
https://www.ravenolamerica.com/passenger-car-products/5w30-motor-oil-ravenol-smp/
Oh. I thought you meant Slovakia. lolSouth Korea
OP's question was about mixing in another oil. Personally, I would just go with a real good 507 oil and not mix. When I bought my Jetta, VW recommended junk Castrol 505.01 oil. I wanted a full synthetic, not a synthetic blend, so I was looking for advice on better oil. The one who answered "Just follow what the owner's manual says.” was not being helpful. I ended up using Motul Specific 505.01, which was a much better oil than the Castrol junk but had to be mail ordered. For the last 200k miles I have been using unapproved Mobil 1 Turbo Diesel Truck.What could you use that’s better than a 507 00 oil?
Well at least in this instance "following the manual" with a 507 00 oil such as the Castrol Edge 5w30 LL won't be recommending "junk".OP's question was about mixing in another oil. Personally, I would just go with a real good 507 oil and not mix. When I bought my Jetta, VW recommended junk Castrol 505.01 oil. I wanted a full synthetic, not a synthetic blend, so I was looking for advice on better oil. The one who answered "Just follow what the owner's manual says.” was not being helpful. I ended up using Motul Specific 505.01, which was a much better oil than the Castrol junk but had to be mail ordered. For the last 200k miles I have been using unapproved Mobil 1 Turbo Diesel Truck.
What junk Castrol oil was this?OP's question was about mixing in another oil. Personally, I would just go with a real good 507 oil and not mix. When I bought my Jetta, VW recommended junk Castrol 505.01 oil. I wanted a full synthetic, not a synthetic blend, so I was looking for advice on better oil. The one who answered "Just follow what the owner's manual says.” was not being helpful. I ended up using Motul Specific 505.01, which was a much better oil than the Castrol junk but had to be mail ordered. For the last 200k miles I have been using unapproved Mobil 1 Turbo Diesel Truck.
In 2005 until I do not know when the VW dealers were recommended a Castrol 505.01 oil for TDIs with the PD engine. The first thing I noticed was it was NOT a synthetic oil, but a blend. Further research showed it to be a blend of Group 1, Group 2 and Group 3 oils. The Motul Specific I went with not only met the VW 505.01 standard but was a Group 3 full synthetic. With the higher flash point (found in the MSDS for both oils) the Motul was a much better choice for a car with a turbo.What junk Castrol oil was this?
If it wasn't for the delicate emissions system (MK7 uses DEF), then I'd just dump Rotella in it!OP's question was about mixing in another oil. Personally, I would just go with a real good 507 oil and not mix. When I bought my Jetta, VW recommended junk Castrol 505.01 oil. I wanted a full synthetic, not a synthetic blend, so I was looking for advice on better oil. The one who answered "Just follow what the owner's manual says.” was not being helpful. I ended up using Motul Specific 505.01, which was a much better oil than the Castrol junk but had to be mail ordered. For the last 200k miles I have been using unapproved Mobil 1 Turbo Diesel Truck.
It should be avail from your dealer for about $9 qt then you know you have the right stuff. Seems to me a lot less hassle.So here's the thing, I'm trying to keep my costs down, I'm buying a house, I have to take care of my dad; and to be honest I find the oil prices for diesel VWs to be ridiculous.
I'm used to spending $20 changing oil with synthetic on almost every car I've had, the STI costs me $30 total because I use Chevron's XSP heavy duty.
Enter my 2015 Golf TDI, my daily; the dealer wants $100+fees. Last time I just ordered the oil change kit for $60, but even that is insane for a freaking Golf.. it's supposed to be my daily cheap beater.
I found Valvoline Euro XL-III... it's $42, and I can get the filter for probably $3-4.
The jug is only 5 quarts and the Golf takes 6, is it okay to mix in one quart of the heavy duty diesel oil I use for my STI?
Chevron XSP 5w40.
***I'm scared of damaging the fragile emissions system in this car, I regret getting this car, my previous Civic Si got almost the same fuel mileage with less upkeep, while being bigger and quicker...
