VW recommended oil
WA
I found this on VWVortex. This is what a guy posted.
originally posted by InProJettar »
The 0 is the viscosity of the oil when it is cold, once it warms up, the viscosity becomes the 30, 40, or what have you. I worked at a lube place and they show you this video and make you take this goofy test with all this sh*t on it before you work there.
It is, of course quite a bit more complicated than that.
I'll try to explain why I believe the low temp rating ultimately has an effect on the high temp protection
of the oil.
You are correct that the 0w gives the tested viscosity at a low temperature (w actually means Winter),
and the 40 gives a high temp viscosity. However, the oil doesn't "turn into a 40 weight at high temps".
It's one multiweight oil tested at 2 *specific* temperatures (like 0C and 100C I believe), and the two
numbers say "At 0C, this oil has the same viscosity that a 0 weight oil would at this temp, and at 100C, this
oil has the same viscosity that a 40 weight oil would at this temperature). All oils no matter what
their weight is, get *less* viscous as they get hotter. ALL OF THEM. A straight 40 weight oil
(would be 40w40.. meaning it behaves like a 40 weight oil at 0C, and like a 40 weight oil at 100C)
is getting thinner and thinner as it heats up. That's just how oil works. It can't actually
be *less* viscous at 0C than it is at 100C, but it can behave like a less viscous oil would..
The trick for making multi-viscosity oils is to create molecules with
long wound up polymer chains, that uncoil and get longer as they heat up. When they're cold,
the molecules are compact and thus less viscous (more runny). As they heat up, base oil gets
less viscous as stated above, but the molecular chains stretch out causing the oil to become
more viscous relative to how its shorter chain version of itself would test at high temps.
Here's what bothers me. This whole stretching trick is neat, but it ultimately has a limit.
The molecular chains can only stretch out so far. The 0w base viscosity should
remain fairly constant as the temperature gets colder and colder because the chains
can't get much smaller, but as it heats up, and gets longer, the tested viscosity must
fall off at some high temp. Assuming the amount that the molecules can stretch is
fixed (I'm sure it's gotten much better over the years, and is undoubtably better in
the more expensive oils) then a 0w base oil will start to fall off at a lower high temperature
than a 5w, or 10w or 15w.
Since the industry only measures it at 0 and 100C (212F)
and we know the *average* oil temp in a VR6 can reach 260+F, and where the oil is in contact with
the pistons and cylinder walls, it's 400+F, how far do you think a 0w oil can stretch it's molecules
to provide 40 weight protection at high temps? How high?
A way to illustrate what I'm talking about is this.
(let's try it as a picture instead of ascii)
horizontal axis is oil weight
vertical is temperature
and each value in the matrix is the tested viscosity relative to the industry standard 0 weight oil.
The 200C row is interpolated to show what I *believe* to be happening, and isn't based on
any test, but simply what I know of the way oils work.
0C and 100C are known, but my concern is that at 200C, the multi viscosity oils will
all show lower viscocities compared to the straight single grade oils and that a 0w40 is
less viscous than 5w40 which is in turn less than 10w40 and 40 weight and 15w50.. etc.
Hope that makes sense. If they made a 10w40 synthetic, I'd probably run that, but they
don't, and 15w50 is just too thick, and always made my car run *hotter*, which
put added strain on the cooling system because the VR6 uses a oil/coolant heat exchanger
to cool the oil, rather than an air/oil radiator
Could not the 150C standards be applied? I know they are high shear but would they not have some relevance?
Minimum
20 = 2.6
30 = 2.9
40 = 2.9 (0W,5W,10W)
40 = 3.7 (15W and above)
50 = 3.7
60 = 3.7
70 = 3.7
This seems to lend credence to your hypothesis.
But then what do I know?
Gene
