TallPaul
Here are the actual listed grades from the tech data sheet on Valvoline All-Fleet Plus Engine Oil:quote:
Originally posted by Jay:
There is no base oil info available, or even implied, in the SAE multi-viscosity designation. Furthermore, there is no such thing as 0-weight, 5-weight, 10-weight, or 15-weight motor oil. These are all valid "w" (winter) designations, however.
15w40
10w30
10w
20w
30
40
50
Of course the multi-viscosity designation does not give or imply anything about the base oil. However, it seems a pretty safe assumption that the base oil viscosity would fall somewhere in the same range as the multi-viscosity designation.
While the Redline info is probably dated (or grossly oversimplified), it made more sense to me than to say the "w" number is approximately the base oil (that idea pops up all too often). I knew an oil company was not going to get a 20-weight base oil (they don't come that way) to build their multigrade, but would use a base oil that, under the API grades, would be a 20-weight (though apparently from the above information it could be thinner than that, or thicker).
What I did not realize, but MolaKule stated, was that they use two or more different viscosity base oils blended together to get the final base oil for a particular multigrade or straight weight oil. Even so, the final base oil blend they come up with will fit the viscosity range of one of the API grades, and on a 20w50 I doubt that grade would be either 20 or 50 for a conventional oil (though the viscosities blended to get the final base oil may well go outside this range).
