VW owners - MIL light P code 0118
Midwest
Wife's MIL light came on in her 06 Golf today. Pulled the code and it traced back to the coolant temp sensor. The sensor is responsible for the readings on the gage as well as sending a signal to the ECM that tells the computer if the engine is hot or cold and if it should run in closed or open loop mode.
Apparently, its not unusual for the signal to the ECM from the sensor to go all wacky. Its an easy 2 minute replacement (pull a clip, pull sensor, unplug harness, plug in new sensor to harness, replace o ring and clip), but I learned after some research, to make sure you buy the part from the dealer which runs like $30 including a new o-ring.
You can pick up a aftermarket Beck Arnley sensor for $23 or a BWG for $10 but these will fail in short order as well. The dealer part is a new design (a green sensor body is the clue that its the redesigned part).
This affects many VW models/engines spanning from about 2000 to 2007.
it is not unusual to lose that coolant temp sensor, either get the specs you need and a DVOM and check yours or throw a new one at it and clear the code
Originally Posted By: ARB1977
Check out German Auto parts. I've got all my replacement parts from there. There much cheaper and are factory parts.
Might be good for some things, but that part in particular was $27 from the dealer + $1.50 for the o-ring. At the site you mentioned the price was $21.50 + $.85 for the o-ring + shipping + waiting a week for it to get here.
For $2 or so difference, I'd rather have the part in hand and fix it right away which took literally less than 5 mintues. I spent more time figuring out how to disconnect the wiring harness clip without breaking it than I did pulling the sensor from the coolant line.
