Hi guys!
I'm here as I'd like to ask for your help choosing the right oil for my car.
The car has around 110k kms on the clock and till now I have always used Castrol EDGE Turbo Diesel 5W-40 (or Magnatec Professional B4 5W-40, that is exactly the same oil but with a different label) http://datasheets.bp.com/bpglis/FusionPDS.nsf/0/6CA628996B77DD50802578DA0061Mobil Delvac 1F5/$file/BPXE-8K8KLX_0.pdf
I've read everywhere that I could use (with excellent results) either Shell Rotella T6 5w-40 or Mobil 1 Turbo Diesel Truck 5w-40 or Mobil Delvac 1 ESP 5w-40; the problem is that here in Europe I can't find any of these (if I could find Rotella T6 i'd use it for almost everything
...) and the only 5W-40 HDEO I can find is Mobil Delvac 1 5w-40 (non ESP).
As Castrol is a grp III, low-saps, API SM oil, it'll probably have really low P and Zn and for this reason it'll perform quite poorly in my PD engine. A good oil to use could be RedLine 5W40, but it has become really expensive here in Italy (19€/qt = 25$/qt), so I was thinking of switching to Mobil Delvac 1 5w-40 (non ESP). What do you think about it?
Thank you very much! Bye!
