I am aware. I've used this oil for a few years and noted reduced oil consumption, excellent cold starts and smoother engine operation. I've also encountered incidences where it reduced or completely eliminated lifter noise in engines that other oils wouldn't help. Of course that is anecdotal, but I'm happy with it. I'm not trying to persuade anyone to buy it. I just thought I'd share the VOA results.Pretty low starting viscosity. Very nearly out of grade. Thanks for testing that. You are aware this is a CI-4 based oil?
Yes, I know you're not trying to influence a purchase just merely sharing it here. Never heard of this company before. If you're happy with the product & service that's all that matters.I am aware. I've used this oil for a few years and noted reduced oil consumption, excellent cold starts and smoother engine operation. I've also encountered incidences where it reduced or completely eliminated lifter noise in engines that other oils wouldn't help. Of course that is anecdotal, but I'm happy with it. I'm not trying to persuade anyone to buy it. I just thought I'd share the VOA results.
I may contact Swepco regarding the viscosity. I've had excellent service with the oil and will continue using it, but that is an interesting observation.Yes, I know you're not trying to influence a purchase just merely sharing it here. Never heard of this company before. If you're happy with the product & service that's all that matters.
Good idea.I may contact Swepco regarding the viscosity. I've had excellent service with the oil and will continue using it, but that is an interesting observation.
I looked up the viscosity range at 100c for 15w40 engine oils, and you guys are correct...at 12.7, this oil is at the low end of the range, minimum being 12.5. below are two other VOA results I have from 2022. One was analyzed by Blackstone, the other by Oil Analyzers. The viscosity for both was 13.7-13.9 respectively, with different additive concentration. https://bobistheoilguy.com/forums/threads/swepco-306-supreme-formula-15w40-voa.352076/Good idea.
Ask them to re-test?I looked up the viscosity range at 100c for 15w40 engine oils, and you guys are correct...at 12.7, this oil is at the low end of the range, minimum being 12.5. below are two other VOA results I have from 2022. One was analyzed by Blackstone, the other by Oil Analyzers. The viscosity for both was 13.7-13.9 respectively, with different additive concentration. https://bobistheoilguy.com/forums/threads/swepco-306-supreme-formula-15w40-voa.352076/
I have asked and will report back with what they say.Ask them to re-test?
Lake Speed Jr said as long as there's enough of a sample available, he'd gladly retest the KV100. I'll let you know the results if there are any.Ask them to re-test?
