Viscosity vs. ambient temperature
California
I live in southern California, where for most of the year it doesn't get below 60 degrees or so. However, in the winter, we do have some mornings where the temps are below freezing, evidenced by frost on the grass and windshields.
The recommended oil for my '97 F-150 is 5w30, which is what I'm using now. The only thing that bothers me about this grade of motor oil is that in a lot of the used oil analysis, it seems to shear down to a 20-wt. in 5000 miles or less. My truck has over 200,000 miles on the clock, so I think a 30-wt. is probably a good choice.
I've read Motor Oil 101, and while I know that not everyone here agrees with the good doctor's conclusions, I understand what he's saying about the thinnest oil being the best at startup.
So I guess my question is this: would it be OK to run 10w30 during the summer months when the morning temp might be 70 deg. F or more (for less shear)? Would it be best to use a 0w30 during the winter months when the temp is sometimes below freezing? Or should I just find a good 5w30 and forget about it.
The recommended oil for my '97 F-150 is 5w30, which is what I'm using now. ...... months when the temp is sometimes below freezing? Or should I just find a good 5w30 and forget about it.
Yes I honestly think sticking with a 5w30 and forget about it is the best approach.
Even if for the same of argument some 5w30 do shear down to 20, many of us have been using 5w30 for MANY years, decades even and never had an oil related failure.
I would say either would work. Personally, I use a 5w30 in my vehicles that call for it and don't worry about it. In my area we see winter temps down to freezing and 110 in the summer, plus I drive to Phoenix several times a year.
Not to mention IIRC your F150 was back spec. to 5W-20 oil.
Stick with the 5w30 and go with a better grade/class of oil. The 333K vehicle in my autosig has been using 5w30 since it was new and it still runs like new.
Just curious - what oil have you used to get to 200,00 miles?
Actually, I just bought this truck. I've put about 4,000 miles on it, and I'm currently using Quaker State Conventional and a Motorcraft FL820s. The engine (4.6L v8) seems to be in pretty good shape as I just passed smog with flying colors. This oil has been in the engine a little less than 2,000 miles, so I'm not sure if it's going to use any or not. It doesn't leak.
I just want to use an oil that will make the engine last as long as possible.
